1985 motorhome - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2009, 08:15 PM
1985 motorhome
ok i know this isn't a hotrod but i hope you guys can answer my question anyway.i have a 1985 southwind motorhome with a chevy 454 on what i believe is a c-30 frame the motorhome is 32 feet-long heres my problem i am having a charging problem for the engine battery its not charging! i checked the alternator and its putting out 14.5 volts on the bench tester at kragen i replaced the regulator and i found i am not getting any juice from the key switch to the regulator does anyone know how i can test the in dash key switch to see if its no good? according to what little info i can get the wire from the regulator is brown thats according to lestek the manufactures the charging system for the motor home does anyone have a wiring diagram for the ignition/charging system for a 1985 c-30 forward control chassis? i am at my wits end but i don't want to waste money on replacing parts that don't need to be replaced if you need more info please email me at *********** thanks guys
Last edited by 302 Z28; 11-28-2009 at 08:17 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 11-28-2009, 08:18 PM
302 Z28's Avatar
Moderators note: Not a good idea to place your email in the body of the thread were it can be picked up by spam bots. Ask that people contact you via PM instead.
Vince
Old 11-28-2009, 10:47 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You could try a Hanes repair manual they have weiring diagrams at the back of the book.
Rich
Old 12-03-2009, 01:26 PM
fast68's Avatar
likes chevy trucks & boobies
if its really a forward control and is 1 ton weight rating then it would be a P-30
C is conventional cab models, IE pickups for example
http://images.google.com/images?gbv=...pell=1&start=0
a P30 was usually a common ordinary 1 ton step van though.
and then there were some other and rare models such as cowl windshield that some buses and other thins were built from
i dont remember the model code of the cowl windshield models
1985 GMC Classic J85Classic Hotrodding Basics 9 06-12-2005 08:31 PM
Initial timing for a 1985 454? sur 454 Engine 6 10-26-2004 04:57 PM
1985 Cadillac Eldorado Problems!?!? fireforsin Engine 6 04-19-2004 04:24 PM
Hei 1985 305 85 chevy p/u Electrical 3 12-02-2003 06:49 PM
1975 Chevy 350 going into a 1985 Monte Carlo Fragzem Engine 2 10-28-2003 09:58 PM
