1985 S10 ,700r4 lock up problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2012, 10:35 AM
New posting here but I see crossley is the 700r4 man.
1985 S10, trans works fine, shifts little late in fourth 53mph
lockup has problems , when cold first few miles will lockup, then goes out.will not lockup after warm,I do have this trans hot wired with toggle switch.also just to note this trans will lockup in third also..my tv cable is set correct,just trying to get ideas before i through parts at it..I thought maby bad torq converter. but when it does lockup it does not slip..also this is a progressive problem it use to work for 40 miles than became less and less like i said it does not shudder when it does go out...thanks in advance for any help.
Old 01-27-2012, 10:57 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
As far as i know "Crosley" works on all types of transmission and is very good at doing so. when he see this he will post .
Cole
Old 01-27-2012, 11:00 AM
sorry, Crosley
Old 01-27-2012, 11:05 AM
eloc431962's Avatar
Wiki Edits: 37
sorry, Crosley
That's ok, but Crosley he will slip in like a stranger in the night and answer some post and be gone before you even know he was there.
Cole
Old 01-27-2012, 06:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You have a leak in the lock up circuit. Could be solenoid, pressure switch could be converter related. When trans gets up to temperature , the problem begins = as I read your post.
Since you have the lockup ''hot wired'' , the pressure switches may be out of the equation on the problem.
Lock up solenoids with age will crack internally and leak.
I would start repairs inside the pan, it is easier to remove than the converter
700r4 lock up problems, engine dies lowandslow65 Transmission - Rearend 10 08-12-2009 07:30 PM
700R4 shift problems with lock-up jeltonb Transmission - Rearend 8 02-27-2009 10:25 AM
1985 astro 700r4 shift problems smit Transmission - Rearend 7 02-20-2009 08:20 PM
Recommended ATF 1985 700R4 AngliaBob Transmission - Rearend 2 11-13-2004 12:35 AM
700r4 in a 1985 gmc truck bassmaster_93202 Transmission - Rearend 2 01-12-2003 06:31 PM
