Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1985 S10 Blazer 2.8 Oil Problems
Old 02-21-2005, 07:27 PM
Mighty Mouse S-10's Avatar
Mighty Mouse S-10 Mighty Mouse S-10 is offline
Cleverly disguised as grownup
Last journal entry: Hollman & Moody
I had a very similar problem on a V-8. found the oil pressure sending unit was leaking. Installed a new sending unit, wiped the oil off the bottom of the truck, and all symptoms disappeared. Good luck. MM
