1985 S10 Blazer 2.8 Oil Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2005, 06:00 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Hey all,
A girl at my school (I don't like her more than as friends, so no teasing, ok?) has a vehicle as described on the thread title; a 85 S10 (small) blazer with a carb'd 2.8 v6.
Well, last week her oil pressure started going up and down a lot, and so she got her oil changed. It's still that way, and she needed to add a quart of oil today. I was speaking with her about it, and she told me the other day the fuel tank was covered in oil.
The both of us wonder what is up with the oiling system on that vehicle; I peeked under the hood, and it's pretty clean, a little dusty from what I have seen. No oil film/mist all over everything like I expected it to be.
Thanks,
matt
p.s. she seems to know a lot about cars, but she's 7 years older than me, and weighs probably 1 1/2 times as much, so don't tell me to take her on a date.
Old 02-21-2005, 06:27 PM
Mighty Mouse S-10's Avatar
Cleverly disguised as grownup
Last journal entry: Hollman & Moody
I had a very similar problem on a V-8. found the oil pressure sending unit was leaking. Installed a new sending unit, wiped the oil off the bottom of the truck, and all symptoms disappeared. Good luck. MM
Old 02-22-2005, 02:37 PM
I agree, I had a 2.8L with the same symptom, and the sender had gone bad and was leaking externally as well...
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 08:44 PM
tpi s10 having some problems blwn98gtp3800 Engine 15 09-05-2008 07:43 AM
1989 s10 blazer 4x4 4.3L 81elcamino Engine 5 12-22-2003 12:15 PM
96 chevy s10 blazer turboed quick jesshwarren Engine 2 11-28-2003 03:15 PM
Blazer S10 4.3 idles poorly bigjack Engine 1 03-30-2003 08:38 AM
