1986 355 swap to zz383 help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 09:54 AM
hey guys I have a 1986 350 small block that is hooked up to my m21 muncie
I believe it is a one piece rear main seal; I have a centerforce dual friction clutch and new flywheel on the 355 engine. i dont know the exact size of the flywheel currently on the car.
I am going to replace the 355 with a zz383 crate motor that comes with an automatic tranny flywheel and flexplate new from GM.
here is the link to the crate engine.
Chevrolet Performance 12498772 Chevrolet Performance 383ci/425HP ZZ383 Engine
I know i cant use the flywheel that comes with the crate engine. (for an automatic) Will I be able to just to take off my old flywheel from the 355 and put it on the zz383?
I will also just use my regular GM HEI distributor and Hooker headers that I had on the 355. i am also going to reuse my old edelbrock water pump on the new 383.
Is there anything I'm missing. i dont know if i would need a special flywheel for the new zz838; and i want to be sure i can reuse my old 350 edelbrock waterpump. my old starter?
any other special tips/tricks when installing the GM zz383
Thanks for you help.
Old 07-09-2012, 12:43 PM
bump... i need some help; im going to take it to the shop wednesday
Old 07-09-2012, 03:12 PM
this is what GM says; can anyone shed some light.
ke all small block V-8 engines produced since 1986, the ZZ383 engine has a 3.00" diameter flywheel flange bolt
pattern. Small block V-8 engines produced from 1958 through 1985 had a 3.58" diameter flywheel flange bolt
pattern. This change in bolt circle diameter was made to accommodate a leak-resistant one-piece rear main seal.
This ZZ383 engine includes a 12 diameter flexplate, part number 14088765. Use flywheel, part number
14088650, with manual transmissions. Also, if using a manual transmission, six bolts, part number 12337973, will
be required.
Old 07-09-2012, 03:19 PM
Greg T's Avatar
www.krusinklassics.net
If the 383 has a one piece seal then you can reuse the flywheel. If it is a two piece you'll need a new flywheel as they have two different bolt patterns. The one piece seal type has a balance weight on it while the two piece does not.
1986 z28 camaro 700r4 swap to tubo350 arthur hawes Transmission - Rearend 3 03-07-2012 07:40 PM
Gm Zz383 Cam And Rocker Swap TOORUDEFORU Engine 16 09-04-2007 11:41 PM
Zz383 Don Meyer Engine 3 05-09-2007 08:57 PM
please help timing a ZZ383 mcgrsr Engine 9 01-21-2005 11:12 AM
