Originally Posted by bigalow
I have 700R4 from an 86 v8 camaro and i will be using it with a 70's 350, supercharged, 177 weind, 6psi boost, daily driver no dragster
What HP nsmissision rebuild kit would be recommended?I here setting up a 700r4 with a blown motor is tricky to get it to shift automatically?
If this is true could I use a manual valve body with this trans? I like manual valve bodies anyway actually
You need to decide what you want in the transmission shifting.. manual shifts or automatic. Valve bodies are available in both configurations.
A manual shift valve body set up with a static main line pressure, will remove the need for a TV cable hook up at the throttle linkage.
Stick with a quality rebuild kit and that company has tech support available when (if ) you need it, may be a good idea
