Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1986 camero knock sensor
Old 12-08-2012, 09:49 AM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
Originally Posted by chphlds View Post
hey guys my knock sensor wont fit where it is supposed to go because of my headers.will it make a differance if i put it at another place on the block where it will fit? thanks for any help.
back on track...
i have the ramjet 350 in my truck, i relocated the knock sensor from the water jacket to a hole over the oil filter for header clearance.
i had to drill and tap the hole for 1/4 npt (pipe thread), it has worked well for 15000 miles.
the ramjet manual recommended against relocating the knock sensor.
but the research i did back then indicated a lot of guys had done this same thing.
