-   -   1986 camero knock sensor (http://www.hotrodders.com/forum/1986-camero-knock-sensor-226932.html)
chphlds 12-07-2012 05:34 PM
hey guys my knock sensor wont fit where it is supposed to go because of my headers.will it make a differance if i put it at another place on the block where it will fit? thanks for any help.
lakeroadster 12-07-2012 07:17 PM
Today's Lesson: C--A--M--A--R--O
There are no "e's" in CAMARO
http://i645.photobucket.com/albums/u...uarterFull.jpg
69 widetrack 12-07-2012 07:27 PM
That is one gorgeous 69 Camero...Sorry couldn't resist, seriously.. about the car though...love the retro traction bars...is it yours?
lakeroadster 12-07-2012 07:45 PM
Yeah it's mine. A true numbers matching SS.... except for the slapper bars, big and littles, Gabriel Hy-Jackers, tri-y headers and Realistic FM Converter.
Period correct "70's era" old school Chevrolet hot rod.
There is an "E" in Chevrolet but no "A". There are two "A's" in Camaro, but no "E".
http://i645.photobucket.com/albums/u...roemblemlg.jpg
69 widetrack 12-07-2012 07:50 PM
I love that era, I built a 67 Firebird with the slapper bars and just the right amount of rear end lift to give the car that aggressive stance...and that was back in the era, I rolled the rear leafs, at that time I didn't trust air shocks...1974...still love the looks.
Beautiful job on the car...takes me back.
Thanks
Ray
69 widetrack 12-07-2012 07:54 PM
You do know I misspelled Camaro on purpose right...LOL
ogre 12-08-2012 09:49 AM
back on track...
i have the ramjet 350 in my truck, i relocated the knock sensor from the water jacket to a hole over the oil filter for header clearance.
i had to drill and tap the hole for 1/4 npt (pipe thread), it has worked well for 15000 miles.
the ramjet manual recommended against relocating the knock sensor.
but the research i did back then indicated a lot of guys had done this same thing.
malc 12-08-2012 11:42 AM
No, we thought you couldīnt spell it right.
malc 12-08-2012 12:00 PM
They must be some pretty tight headers to prevent the use of the knock sensor. Is there the same issue on the other side of the block because there is a drain plug opposite the knock sensor, maybe you could fit it there ?
http://www.hotrodders.com/gallery/da...Right_Side.jpg
Just about visible.
http://www.hotrodders.com/gallery/da..._Left_Side.jpg
496CHEVY3100 12-08-2012 01:25 PM
good choice like head studs ,roller rockers,i"m gussing 350, does rear sump pan fit
lakeroadster 12-08-2012 08:52 PM
Yep.. :welcome:
malc 12-08-2012 11:52 PM
350, itīs in my....:evil:....Camaro.
Old pic, same rockers etc., now has aluminum heads, knock sensor deleted.
chphlds 12-09-2012 09:14 AM
knock sensor
thanks for the info guys.more room on the opposite side of block.think i can squeze it in there.
malc 12-09-2012 10:50 AM
The motor I posted is in my 86 Camaro, Iīm using Hedman Hedders.
http://www.hotrodders.com/gallery/da.../Headers_I.jpg
Hedman Y pipe into a Flowmaster 3", single driverīs side outlet.
http://www.hotrodders.com/gallery/da...Flowmaster.jpg
My knock sensor went with the computer when I chucked it out,
but there was plenty of space for it.
chphlds 12-10-2012 12:45 PM
knock sensor
if wires dont reach,i will use your sugestion. thanks for the help
