Yeah it's mine. A true numbers matching SS.... except for the slapper bars, big and littles, Gabriel Hy-Jackers, tri-y headers and Realistic FM Converter.
Period correct "70's era" old school Chevrolet hot rod. There is an "E" in Chevrolet but no "A". There are two "A's" in Camaro, but no "E".
Beautiful job on the car...takes me back. Thanks Ray |
i have the ramjet 350 in my truck, i relocated the knock sensor from the water jacket to a hole over the oil filter for header clearance. i had to drill and tap the hole for 1/4 npt (pipe thread), it has worked well for 15000 miles. the ramjet manual recommended against relocating the knock sensor. but the research i did back then indicated a lot of guys had done this same thing. |
It is oem or after market system. You may be able to find some cars that had them in different place maybe check where there at on then vette with the headers they have. You can change the sensor type sometimes and be ok look and see if a low profile sensor is available or different headers. Some times you can modify the sensor or headers to work with it. If you only need a little room to make it fit. Smack the header with a hammer and put a dent in it so it can fit. Certianly not a perfect solution. |
They must be some pretty tight headers to prevent the use of the knock sensor. Is there the same issue on the other side of the block because there is a drain plug opposite the knock sensor, maybe you could fit it there ?
![]() Just about visible.
good choice like head studs ,roller rockers,i"m gussing 350, does rear sump pan fit
....Camaro.Old pic, same rockers etc., now has aluminum heads, knock sensor deleted. |
The motor I posted is in my 86 Camaro, Iīm using Hedman Hedders.
![]() Hedman Y pipe into a Flowmaster 3", single driverīs side outlet. ![]() My knock sensor went with the computer when I chucked it out, but there was plenty of space for it. |
| Knock Sensor | tommy evans | Engine | 5 | 08-21-2010 07:02 PM |
| knock sensor | 88chevy | Engine | 8 | 06-18-2006 11:56 PM |
| knock sensor | the_sellars | Engine | 1 | 02-06-2005 04:49 PM |
| knock sensor | jo5hi3 | Engine | 10 | 10-29-2004 02:00 PM |
| knock sensor | jo5hi3 | Engine | 1 | 10-28-2004 02:59 PM |
