1986 Chevy 350 - Plug for Choke Riser Tube Hole in Exhaust Manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2010, 07:29 PM
kbuhagiar's Avatar
47 Plymouth Special Deluxe
Hello Folks,
Worked on the 47 Plymouth today. It has a 1986 Corvette 350 TPI engine.
I discovered that there is a hole in the passenger side exhaust manifold, which goes all the way through into the #4 exhaust port, and appears to have been used for a factory choke riser tube.
I would like to plug this hole, as I assume that it is causing an exhaust leak. It measures exactly 1/4". Should I just drill and tap it for a 5/16 x 18 plug, or is there some other sort of simple plug I can tap in and be done with it?
Thanks in advance.
Old 10-18-2010, 03:18 PM
bigdog7373's Avatar
Of course it's fast
I say tap it and put a bolt in it. But why would you have a choke if the engine is fuel injected?
Old 10-18-2010, 07:50 PM
kbuhagiar's Avatar
One vote for tap and bolt.
I have determined that the exhaust manifolds are not the originals; these were sourced from an earlier small-block Chevy, perhaps to make for a better fit into the Plymouth frame.
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 06:47 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Chevy 350 Intake Manifold Gasket morenbd Engine 4 07-11-2004 05:05 PM
'97 crate 350 - what edelbrock manifold? THC3PO Engine 5 06-28-2004 04:56 PM
