1986 chevy k10 with t-350 and clunking - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 06:25 PM
86 k10's Avatar
i have a 1986 chevy k10 it has a 350 smallblock and a thm-350 3 speed auto trans. but when i put it in reverse it makes a clunk and the back of the truck pops down. whats wrong with my trans???
Old 11-07-2008, 07:41 PM
Do you have a lift kit? It sounds like the universal joints might be bad on the rear driveshaft, or something else is loose and allowing quite a bit of play. A lift kit often puts a lot more stress on the driveline because it screws up the pinion angle.
Bruce
Old 11-07-2008, 08:47 PM
U-joints mostlikely, could also be a broken,or loose transmission or engine mount.
Shane
Old 11-07-2008, 09:44 PM
sounds like a bad u joint to me.
Old 12-14-2008, 03:20 PM
86 k10's Avatar
it was a u joint thanks yall
