1986 Chevy Monte Carlo, mayb 200r4 problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 10:22 PM
I have a 1986 chevy monte carlo 305 with a 200r4, the car is running purely mechanical no electronics on the engine. I did a few things to give it more power but its soo sluggish and i believe its the transmissions fault, it never wants to shift right usually winding out in first gear then slamming into second and does not want to kick down to pass anything.
Tv cable was adjusted by me and a professional transmission place neither made the difference. I heard the transmission is controlled by the computer is there a way to get around this? and anything else could cause this?
Old 07-22-2011, 11:24 PM
No computer on 2004r, ck the gear on the gov has bad teeth or the gov is stuck
Old 07-23-2011, 01:32 PM
SSedan64's Avatar
What Carb are you using now?
Have you installed a Lockup kit for the TC Clutch?
Old 07-23-2011, 05:45 PM
tnsmith10's Avatar
when will it rain???
what did you do to the engine to give it more power? did you swap the toque converter at the same time to match the cam if you put another cam in? what rear gears are in the diff?
more often than not, this is a result of a big cam installed and not also installing a new higher stall converter to match the cam.
also, if the car was fine before the work was done, then odds are that the problem is related to the work done.
on the shifting of the car, if its shifting late and hard and you have no passing gear, if what i mentioned above is not related to whats going on with the trans, then it just doesnt have enough tv pressure set in the cable, or it could be a combination of both.
Old 07-23-2011, 11:12 PM
cam and rear are stock, no computer a edelbrock carb and headers with side pipes the tv cable seems spot on how to adjust it and even a trans place did it before with no difference and no i dont have a lockup kit
Old 07-24-2011, 07:29 AM
SSedan64's Avatar
Do you have the TV cable geometry Corrector Bracket on your Edelbrock Carb? > http://www.summitracing.com/parts/SUM-700203/
Old 07-24-2011, 07:43 AM
RippinRon's Avatar
Like said before you need the proper tv cable bracket for the edelbrock carb. And the proper way to adjust them is by measuring the line pressure with a gauge. Read
1986 Monte Carlo T-Top Noel Ortiz Body - Exterior 1 06-28-2011 09:48 PM
1972 Chevy Monte Carlo trans problems 72 M.C. Transmission - Rearend 6 04-14-2010 10:48 AM
Rear end for 1986 Monte Carlo SS McSS86 Transmission - Rearend 7 02-01-2010 12:55 AM
1986 Monte Carlo FordTruckMan_MB Introduce Yourself 1 02-27-2009 11:09 AM
200r4 install in a 72 monte carlo rats monte Transmission - Rearend 7 01-04-2009 02:19 PM
