Hotrodders Bulletin Board
#1
1986 Cutlass Motor mount and vacuum line questions
Hi
(5.0 307 Y in vin) I recently picked p a Cutlass that im trying to fix up. The people who owned the car before really didn't take care of it. I recently replaced the valve cover gaskets and intake manifold gaskets. Painted both of em to make em look better. Then replaced the motor mounts. So far though im wondering if y'all can help me find out where some of these things go. This clip right here I know nothing about. Does anyone have a Cutlass and can tell me where it goes please. Here are some pics of it. I don't see and area on the intake or carb that it is missing off of.. ![]() ![]() ![]() There is also this black vacuum line tube that was broke off. I don't know where it should plug into. ![]() ![]() Also these two vacuum lines in the back left passenger side of the car are broke. I don't know where they go. ![]() They are located back here. ![]() Also another thing.. When I got the car the motor mounts were shot. THe motor was basically laying on the cross-member. I replaced the motor mounts. The engine feels good and looks good but the engine now sits up too high for some reason. The fan rubs on the fan shroud and the hood will not close cause it hits a bracket and is really close to hitting the fan. Has anyone had this problem before? Does anyone know how I can fix it? The engine looks like it tilted up like the Tranny mount are loose or something cocking the engine up.... But the motor mounts are on right. I dunno does anyone know why everything is so close the the hood? ![]() Any help would be great. Thanks, Chris Last edited by ChrisMiddleron : 05-16-2005 at 01:59 PM. |
#2
re: 1986 Cutlass Motor mount and vacuum line questions
The plug appears to be the one that would go to a electric choke, but the car has a hot air choke, I`ve seen many like this that have the electric plug in there and there car not have a electric choke. Don`t quote me on that as far as it being for a electric choke. Is the A/C high idle solenoid in place and plugged up? the connector could have been for a heat pod under the carb. The broken vacuum line looks as if it goes to the vents, I`m not sure on the black one, but I am on the pink one, as mine is also pink, make sure the vent controls work, if they don`t go from there. For some reason mine has 2 lines for the vent controls, my friends who have a cutlass only have one. Check the tranny mount and make sure it`s still good, it can be broken and not appear to be, this can cause the engine and tranny to move around as well as make the tranny bump under the car, if the rear of the tranny sits low enough it makes the front of the engine hit the hood. The black vacuum line could go to the exhaust flap but don`t quote me on that either. These cars had miles and miles of vacuum lines, and a real pain to replace them all. Is the catalyst still on the fan shroud? it should show you the vacuum line diagram. When I got my 86, I drove it for about a year and ripped out the 307 and dropped in a small block chevy as I`m not a big fan of Olds engines.
I also swapped in a posi carrier and gears from a 83 Trans Am, my car came factory with 2.14:1 gears, highest gears I ever seen in a passenger car. |
#3
Thanks for the help
On 3 forums you have been the most help. I took out the old tranny mount t-day and it evened out the engine about a inch. The engine is still sitting high though. I hope they didn't sell me the wrong motor mounts. They bolted up fine..... But maybe they are thicker then the originals making the engine sit higher. |
#4
HEY ChrisMiddleron-
Just want to add my two cents... the little green tab thing is for diagnostics for the puter and carb. it just hangs there. the black vacuum lines go the the emissions controls on the pass side of the vehicle. air pump and air release to heads. i own a 86 cutlass supreme and have redone all the vacuum and hard lines on the sucker. i was lucky that mine is pretty clean. i have a 86 manual at the house...will scan you some pages and post em for you tonight....wish id seen this thread earlier- happy to help a fellow olds owner. pm me if you need anything else. you may also want to take a look at oldspower.com - great bunch of persons there...i have the same handle there - but dont leave this site completely now ![]() |
#5
Thanks for the info
Thanks for that web-site. I will check it out now. That would be really cool of you to scan and post them pages. Thanks for everything, Chris |
#6
I was going to mention the same site to you, as I`m a member there myself under this same name.
#8
Im in no rush. Right now im waiting for that forum to email be back so I can activate my forum account
Takes forever.. Now I think the fuel pump went bad on the car. |
Back to top |
Similar Threads for: "1986 Cutlass Motor mount and vacuum line questions"
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 34 | 07-26-2008 04:59 PM |
| Vacuum adv.. | underdog305 | Engine | 58 | 01-30-2007 11:19 AM |
| Port or Full time vacuum | cool rockin daddy | Engine | 31 | 04-03-2006 12:06 PM |
| Vacuum advance hooked up directly to manifold....is this bad????? | Steve-0321 | Engine | 64 | 09-13-2004 08:33 PM |
| vacuum advance help | batman09 | Engine | 14 | 09-09-2004 09:42 PM |
