1986 Cutlass Paint Project Pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2005, 09:00 PM
ChrisMiddleron's Avatar
Sup
Heres the new project. Everyone who knows the car called it the Cutty Mack so thats what ima call it.
Just fixing dents and Primering right now.
Im using Evercoat Rage Gold bondo, Evercoat Easy Sand Glaze, and Evercoats new line of SlickSand primer.
Some pictures of before.
Gotta fix the messed up door striker panel.
Theeeee roof works though
Old 06-26-2005, 09:01 PM
More random pics
Finally getting around to throwing some primer on it.
This is the grey primer with the black guide coat on it.
Old 06-26-2005, 09:02 PM
So far t-day iv been wetsanding with 400 grit. I think im going to dry sand the car with 220 on the da then wetsand it with 400.
Its coming out straight tho. So far I gotta glaze a few small spots on the bumper and just add a couple coats of primer on the area by the roof and im good so far. The area I bondod is perfect.
It all aughta be sanded by tomorrow. Then I just gotta do the touch ups/prime/scuff and im done with the outside.
Get-er-done
Finally done with the wet-sanding
Now I gotta glaze the pin-holes and scratches that the primer didn't fill. Then spot primer the areas I think need a little more primer make the panel level.
All the areas I bondod dont need no work at all though. I shocked myself this time around.
Old 06-26-2005, 09:03 PM
A little stereo crap I play on putting in the car. If it all fits :machinegun: Ill get it in..
I wonder if you can paint amplifiers?
The drivers side striker panel metal was cracked. The door striker panel was a hole. You could actually see the backing plate that the stud screwed into and everything. I welded everything closed. Grinded it lightly then I kitty-haired / bondod/ glazed the panel till it was hella right.
Here was how it used to sit before.
Old 06-26-2005, 09:04 PM
Get-er-done
I used some more Evercoat primer and some rattle can as a guide coat. It was a windy day.. THe guide coat was a pain to spray.
This aughta bee the last time primer is needed on the body. I just wanted to make sure some areas were right.
Old 06-26-2005, 09:05 PM
I still dont know what ima do as far as ventelation or however it is spelled. I usually just keep the garage closed while spraying and while it is flashing I open the garage. I have allot more neighbors though. Get-er-done
The outside is DONE! I just got a few touch up primers on the hood to sand off and its done. Now I just gotta do the jambs and stuff.
Shes all masked up
Now im just going to re-scuff-clean-tackrag-spray
Im going to be spraying it a House of Kolor PBC-63 Lake Violet Pearl
Or a Shimrin Kandy Oriental blue / Cobalt blue. It just depends on what the paint store has in stock.
Im really wanting that lake violet pearl. Its going to make the paint stand out with the chrome allot.
Old 06-26-2005, 09:06 PM
Finally got it painted. This paint looks great with chrome. It looks cool blue when any light hits it then it turns purple in the shade. The color kicks *** though.
I wasn't able to make any type of paint booth setup. Locally they charge like 200 extra on paint then online. It sux but o well. Ima poor boy for a while.
Here are some pics of sealer
Old 06-26-2005, 09:08 PM
I layed off/white sealer and then some orion silver just for the hell of it.
Old 06-26-2005, 09:09 PM
The House of Kolor tech manual said it takes 6-8 quarts to paint small to average sized vehicle. O well. It only took 3 quarts of both paint and clear to paint the car. I got 3 coats of paint and 4 of clear.
Old 06-26-2005, 09:10 PM
Looks at that baby roar
Cameras suck
Ill get some pics of it out in the sun with all the chrome on tomorrow. I got all the trim on t-day but it was too dark for pics.
Here is sneek peek tho.
More pics will be posted tomorrow. Pics will also be posted when the cutting and buffing are done. Im gonna let it bake hella good in the sun before cut-n-buff.
Old 06-26-2005, 09:12 PM
Man that fresh paint sure does make old chrome look like hell. Paint still needs cut'n-buff big time.
So far I think HoK clear great. It holds its gloss unlike the Martin Senour CC-5000 I have been using since I started painting.
Usually the Martin Senour cc-5000 clear would loose gloss as it cured. HOuse Of Kolor clear is worth the extra moola.
[IMG]
http://img284.echo.cx/img284/4404/d306ig.jpg[/IMG]
Old 06-26-2005, 09:13 PM
Gotta love the factory sunroof that works.
It needs some 13"s along with some new chrome and weatherstripping tho
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
Basic of Basics - Choosing a color Centerline Body - Exterior 1 11-26-2005 09:12 PM
54? Chevy sedan ChevelleSS_LS6 Hotrodding Basics 27 06-12-2005 02:11 PM
Paint choice? daimon1054 Body - Exterior 2 10-29-2003 11:02 AM
1st painting nova33 Body - Exterior 19 06-16-2003 10:05 AM
