1986 F150 351W wiring diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2009, 02:04 PM
1979 Trans Am H-A 403
ive noticed plenty of diagrams for the f150 1986... im having troubles finding a wiring diagram for the 351 windsor tho. all of the harness is shot so i am doing a rewiring job. i got most done but theres some wiring that was missing or fell off. does anyone have a page of a diagram that shows alternater or ignition, or the alt regulator or perhaps the whole damn thing? it would help alot thanks guys
Old 09-06-2009, 08:45 AM
Wiki Edits: 27
local resource center.
When I was a kid we called it the library. some have a reference area with shop manuals that you can copy the pages you need.... no more check out because of all the greasy fingerprints on the old ones,
Old 09-06-2009, 09:09 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Autozone can save you that trip to the lie-berry. Membership is free, and you can even set up service reminders / recall notification fo your "fleet" of vehicles.
I use their wiring diagrams a lot. They're a little hard to find ... but they're usually there.
Old 10-08-2011, 06:23 AM
wiring
need to know how to wire under hood 1983 f100
Old 10-08-2011, 09:47 PM
66GMC's Avatar
Erm
The diagram above doesn't help?
The easy answer?
Go to the junkyard and find similar trucks / engines / drivetrains / trim level / etc, then compare wiring harnesses.
Ford actually identifies their wiring harnesses with an engineering number, which can be found on a label right on the harness.
Look for a number in the following format: E3TE-14401-A2A (or similar)
If you find one that is VERY close to what your own is (i.e E3TE-14401-A3A) ... jot the number down and head to your local Ford dealer's parts department.
They should be able to check and verify if they are the same or not, and possibly what is different. (lights versus guages for example)
1986 t-bird alt wiring diagram 55 dude Electrical 1 07-30-2007 04:34 PM
1996 Big Block Chevy Wiring Diagram Sick56 Electrical 2 01-02-2006 02:31 PM
1956 chevy belair Wiring Diagram NAK Electrical 1 05-12-2005 09:22 PM
Wiring Diagram for 88 & 86 S-10 cas2042 Electrical 1 03-16-2004 09:20 AM
wiring diagram for 1986 trans am 1986 Trans am Electrical 3 10-20-2003 05:00 AM
