Check the throttle bore sizes between the primaries of the four barrel and the two barrel. I'll bet the four barrel primaries are smaller. All you have to do is keep your foot out of the secondaries.
I thought the same thing, before I ever drove in the truck with him. He drives like a grandma. Almost never goes over the speed limit (maybe to pass someone, but never cruising), takes forever for him to get to the speed limit... When I drive the truck, I mob around in it, and pedal to the metal it. =D He's the one getting the consistently bad mileage though.
With computer contolled injection I am getting 15-16 in an f150 4wd...you might get there with a carb but I dunno..best thing I ever did for mileage on a 4bbl was to set it up so it took a lot of throttle pressure before the secondaries opened..that and a good tuneup..check for vacuum leaks..and make sure you are getting the proper advance in the dist..
If it is a high miler you may be getting some blowby so do a leak down test and a compression test to ascertain engine condition.. If it is currently an automatic and a high miler the bands may be slipping just a bit..combined with the engine issues the tranny could be part of the issue..Just takes a bit here and a bit there and mileage goes in the dump.. Sam
I personally am not a big fan of quadrajets but they do get great fuel economy, so If you buy a spreadbore dual plane manifold for the 351W and put a quadrajet on it and adjust the secondaries to come in late, plus your T5 tranny I see no reason you couldn't get 16 mpg out of it or even more. The small primaries in a quadrajet give it excelent fuel economy thats better than most 2 barrels ever thought about getting.
Unless you want to castrate the truck to a very low GVW, steer clear of the T5. Its not a terrible choice, but why put a light-duty car transmission in a truck?
NV4500 is what you want. Good ratios for a truck, good torque capacity, and good GVW rating. |
Sounds good. The motor is new. Good compression. Q-Jet, huh? =D I don't know how to adjust the primaries and secondaries. I'm used to my little 1 barrels on my sixers. =D Great economy there. Thanks for the info guys, I'll go out and do some more research, talk to my bud, see what we wanna do, and shoot back. =]
| Ford F150 engine | Thuggishruggish3000 | Engine | 4 | 01-24-2004 02:39 PM |
| ID Numbers on a 1986 350 SBC Head | redcamaro4spd | Engine | 6 | 05-26-2003 06:12 AM |
| 1986 F350 XLT tilt wheel ??? | BeerMan | Suspension - Brakes - Steering | 8 | 03-07-2003 07:28 AM |
