-   -   1986 Iroc 5 spd Flywheel and Clutch > Fit's 4.3?? (http://www.hotrodders.com/forum/1986-iroc-5-spd-flywheel-clutch-fits-4-3-a-101874.html)
boneyard Buick 11-06-2006 02:33 PM
hey guys
i know the 5 spd will bolt up to the 4.3L but i know i have to get a 4.3L flywheel because the 4.3's are externally balanced. When i do this, can i still use the new clutch i have that was meant for the 5spd when it was bolted up to the 305 TPI motor? will the clutch match up to a 4.3L flywheel?? or do i need to get a new clutch? i'd rather not because this is brand new but im just curious. Thanks :thumbup:
the t-5 was from a 1986 Camaro IROC with 305 TPI
the tranny is going into a 1989 s10 blazer 4.3L (currently th350)
barnym17 11-06-2006 02:55 PM
better check I think some were internally balanced.Look to see if there is a balance weight welded to the 4.3 flywheel.
boneyard Buick 11-06-2006 02:57 PM
i know the camaro flywheel wont work on the 4.3. i need to get a 5 spd 4.3L flywheel and i was just wondering if the camaro clutch would work on the 4.3L 5spd flywheel. They are externally balanced, there is weights on the flywheel thats why i need a flywheel from a 4.3L 5 spd.
barnym17 11-06-2006 09:11 PM
check the diameter of the v8 clutch, then check with the parts store fore the diameter needed for the 4.3 flywheel.Probably will work.
