1986 Iroc 5 spd Flywheel and Clutch > Fit's 4.3?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2006, 02:33 PM
boneyard Buick's Avatar
hey guys
i know the 5 spd will bolt up to the 4.3L but i know i have to get a 4.3L flywheel because the 4.3's are externally balanced. When i do this, can i still use the new clutch i have that was meant for the 5spd when it was bolted up to the 305 TPI motor? will the clutch match up to a 4.3L flywheel?? or do i need to get a new clutch? i'd rather not because this is brand new but im just curious. Thanks
the t-5 was from a 1986 Camaro IROC with 305 TPI
the tranny is going into a 1989 s10 blazer 4.3L (currently th350)
Ryan350 :thumbup:
Old 11-06-2006, 02:55 PM
better check I think some were internally balanced.Look to see if there is a balance weight welded to the 4.3 flywheel.
Old 11-06-2006, 02:57 PM
i know the camaro flywheel wont work on the 4.3. i need to get a 5 spd 4.3L flywheel and i was just wondering if the camaro clutch would work on the 4.3L 5spd flywheel. They are externally balanced, there is weights on the flywheel thats why i need a flywheel from a 4.3L 5 spd.
Ryan350 :thumbup:
Old 11-06-2006, 09:11 PM
check the diameter of the v8 clutch, then check with the parts store fore the diameter needed for the 4.3 flywheel.Probably will work.
1986 Iroc 5 spd Flywheel and Clutch > Fit's 4.3?? boneyard Buick Transmission - Rearend 7 11-11-2006 09:10 PM
M21 to M22 - clutch and flywheel help DarwinBrooks Transmission - Rearend 13 02-08-2006 06:33 AM
ford flywheel and clutch question dusterbd Transmission - Rearend 1 10-16-2005 05:25 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 07:44 PM
clutch disc springs hit flywheel bolts 72chevy240z Transmission - Rearend 6 05-05-2004 03:21 PM
