1986 pontiac acaidian with a pontiac 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2005, 07:03 PM
mazmanian's Avatar
no progect,no money,pissed off
i have a 1974 pontiac big block that was out of a t/a i wanna bore it to 467 cubes and drop it into a 4 door acaidian . But my question is that what will be the biggest job of this project if anyone knows please let me know oh ya i also have 2 automatic trannys that are a little diffrent one another one has a longer tail housing right where the drive shaft slides into the othe rone has a shorter one as well as one of them has a shift kit 3500 rpm .
467 cu.in. of pontiac power is hard to beat
Old 07-30-2005, 07:43 AM
Parisienne66's Avatar
There was a guy in Quebec city I saw that had modified a Chevrolet Chevette (2 Door) and put a Chevy 350 in it. Room is going to be your main problem with this project. you can either lenthen the front end to accept the V8, or Cut out the firewall to fit the v8. The guy I had seen had taken the hard way, Cutting and rebuilding the firewall. In his case, he had cut the windshield and notched it to enable the Air intake Bol to be there. Driveshaft was a custom model etc etc etc. The car was a racetrack vehicule only, and Hence he didn't mind the modifications, but that would surely make any vehicule a Mostly track vehicule. Also, the guy said the car's short wheelbase was a problem, because traction was a problem at the track. The car tends to wheelies, keeping it straight is hard etc...Larges tires at the back, short wheelbases and lots of power don't go well together he said...
This is a Big project, but doable, I've seen it. I can only imagine what the design needs are and I'm sure the guy spend countless days thinking over his project and countless nights raging about troubles he's faced. But the rewards and satisfaction of being able to do it must be nice also..
Good luck with your project.
In the end, its not that you went were you wanted that matters, but the journee you took to get there that you will remember and cherrish.
Based on Homer's Philosophical writings.
Old 07-30-2005, 01:35 PM
mazmanian's Avatar
hey thxs parisienne66, i dont know to much about lenghting the frame but cutting the firewall wouldn't be a bad idea. I also have seen a sbc in a chevette a 355 with nitorus and my buddy put in a 427 big block in a chevette as well but is'nt the 400 pontiac wider than the 427 wider as in the heads are farther apart than a normal big block ??
Pontiac 400 vs. Pontiac 455 chevyelc81 Engine 7 03-19-2011 07:31 PM
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
Pontiac 400 88bluebird Engine 8 12-04-2005 01:17 PM
Will a pontiac 400 fit CamMan Engine 10 11-21-2003 05:46 PM
will a 1969 455ci olds engine bolt right in place of a pontiac 400??? chevyelc81 Engine 3 06-12-2002 03:54 AM
