1986 s-10 truck steering shaft linkage worn? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2006, 01:13 PM
Hello I am trying to tighten up the steering in this truck and am lookin at the steering wheel, and its associated linkage that connects it to the gear box........Does the shaft coupler to the gear box that has the rubber universal joint go bad? I tried to move it back and forth against itself and it does move a little, are these things supposed to be rock solid with no play or should I just fix the up and down thing that the steering wheel does due to loose tilt bolts inside the column?..........and i am still deciding if I should get the tool to totally take apart the column or just locktite the bolts I can get at and leave it at that. I know there are 4 bolts to tighten but whats the draw backs of only tightening two.........any ideas would be apprieciated.....thanks
Old 07-17-2006, 01:30 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Yes tighten the steering wheel first. The idler arm is more than likely loose, along with most of the steering linkage. The rag joint will have some play but not much.
Steve
Old 07-17-2006, 08:57 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Something else to check.
On the intermediate shaft, above the rag joint there is another joint (GM manual says pot joint) over time they can wear. I replaced the shaft on my Bravada (S 10 Blazer) with a new one from GM, I checked into aftermarket and couldn't find any that bolt in. Borgeson makes all of the parts but you would have to fabricate, cost was going to be similar.
Old 07-19-2006, 07:55 AM
the steering shaft can be replaced with a jeep grand cherokee shaft from any junkyard. check out s-series.org for the write-up
Old 07-21-2006, 10:42 PM
Fix the steering column first. Than replace the rag joint with either a new rag joint or the grand cherokee shaft already mentioned.
http://buickperformance.com/tiltstee...lumnwobble.htm
Ford Truck Steering woes Kaylah Suspension - Brakes - Steering 4 08-15-2008 05:09 PM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 04:57 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Know anything about power steering on a 70 chevy truck? billp Hotrodders' Lounge 1 09-10-2002 04:02 PM
1956 Chev Truck Power Steering vaughan Suspension - Brakes - Steering 2 09-06-2002 12:11 PM
