1986 z28 camaro 700r4 swap to tubo350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2012, 08:49 AM
I would like to know if there is an aftermarket bracket to bolt a turbo350 in this car.
Old 03-06-2012, 11:43 AM
SSedan64's Avatar
I've seen them on Evilbay, can't remember brand. Possibly 'Spohn Performance' > http://www.spohn.net/
The TH350 w/9" Tailhousing is the same length as the 700R4, I'm not sure if the F-body 700R4 Tailhousing will bolt on & work or not. Someone on here should know.
http://www.ebay.com/itm/Spohn-Adjust...item43ad6501ff
http://www.ebay.com/itm/Spohn-Transm...item43ada86e3e
Old 03-07-2012, 08:00 PM
6426yy's Avatar
http://www.google.com/products/catal...ed=0CD8Q8wIwAg
Used this in my 84Z.
Old 03-07-2012, 08:40 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
b &m have made the complete bracket kit for years..
it comes with everything you'll need.. to install a th350 or a th400
1980 camaro 700r4 swap High School Hot Rod Transmission - Rearend 3 10-22-2009 07:09 AM
1986 camaro 700r4 BlackCamaro Transmission - Rearend 4 11-03-2008 10:34 PM
tubo350 Kick down cable problems Aboveknee Transmission - Rearend 14 10-30-2008 06:51 AM
1986--700R4 Transmission Bill Burkett Transmission - Rearend 1 08-23-2008 05:40 PM
92 camaro w/305 and 700r4 tranny swap to t-5 1sttimebowtie Transmission - Rearend 3 08-11-2008 12:23 AM
