1987 350 TPI Overheating
I took the old tpi 350 out and got a new long block. When i put it in i replaced the water pump, the timp swich and sensors and had the radiator checked out and was fine. My car runs fine and is at 195 timp at idle but as soon as you hit the gas it overheats. I had the car looked at and they could not help me and i am out fo ideas and need help fast. It is in a Z-28 Camaro
Check your timing. Be sure the vacumn line to the advance is unhooked and plugged when you set it.
The motor is on time and vics are right
Check out the fan clutch. Look for any leaks around it, if you find any replace it. Try and spin the fan after the motors warmed up, if it moves and is not hard to turn, replace it. When the motor is cold, it should spin relatively easily.
it has a elctic fan
Eek! My mistake, disregard last post..
it heats up in n when i give it gas
Did the old engine overheat when you gave it gas? Ed |
it will steadly heat up to about 240 as soon as you give it some gas
The old motor did not
What style of belts/pulleys are you running? Ed |
Im still running the 87 year pullys and i have the right water pump i checked it already
I know you said before that your timing is correct but what is it at?
What did your intake manifold gasket look like? The rear ports on some of the gaskets have block off plates in them, some engines may or may not need these. I would look here if all other suggestions have been investigated.
Steve |
| Tpi 305 To 350 | Teejay68 | Engine | 3 | 11-26-2004 12:43 PM |
| retro fitting EFI or TPI on carbed 350 | Jag Daddy | Engine | 3 | 05-12-2003 12:51 AM |
| tpi on early 350 | 48fordnut | Engine | 3 | 05-08-2003 03:21 PM |
| TPI 350 Distributor installation question? | mySR7D1 | Engine | 6 | 04-06-2003 04:25 PM |
| Comression ratio on the 1991 and 1992 350 TPi chevy engines | taleb1 | Engine | 1 | 01-18-2002 12:43 PM |
