1987 Blazer K5 TBI issues. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2010, 09:07 AM
I recently replaced my fuel pump, and noticed my fuel gauge operated in reverse, so I switched the wiring around in the factory electrical clip and it fixed the gauge issue. but I still am not getting fuel to the throttle body. I hear it running in the tank, not 100% sure if its running in the right direction though. What powers my injectors? maybe they took a dump? or am i not bleeding the fuel line properly? any thing would help.
Old 10-23-2010, 09:50 AM
bigdog7373's Avatar
Of course it's fast
Make sure you wired the pump correctly. Also this may sound stupid, but is there any gas in the tank? I actually made this stupid mistake and though my mech pump finally died so i went out and bought an electric one an the engine still wouldn't start. Turns out it ran out of gas while it was idling in the driveway; boy did i feel like an idiot. Also, make sure the injectors are working correctly and their not clogged up.
Old 10-23-2010, 10:23 AM
I have plenty of gas, I'm thinking i might have replaced the pump for no reason, maybe its my injectors. I'm unclear on what to do with this 87 TBI setup, is there a relay or fuse for the injectors i'm not seeing?
Old 10-23-2010, 10:45 AM
bigdog7373's Avatar
Of course it's fast
There's a fuse for everything so check the one for the injectors. Make sure the fuel filter is clogged.
Old 10-23-2010, 04:40 PM
well the injectors are working now, but it still wont fire. Not sure if the ignition module failed or the coil. I dont know how to determine which it could be.
700r4 in K5 Blazer recomendations 1slow64 Transmission - Rearend 2 07-29-2010 07:47 PM
1982 k5 blazer w/305 want to install a 700R4 trans krubious Transmission - Rearend 4 07-08-2010 05:02 AM
TBI Questions on a 93' Chevy FS 350 IWANTMOREHP Engine 1 01-04-2004 01:42 PM
1987 tbi to a 1997 350 sfi vortec g.b. Electrical 0 10-19-2003 05:32 PM
383 Stroker - '90 K5 Blazer mikebain Engine 3 10-02-2003 09:02 PM
