1987 Caprice rear end
i want to change gears in my rear end but i dont know what inch rear end i have in my 87 caprice.
7.5" 10 Bolt.
http://novaresource.org/axle.htm has pics that will help you see if it's an 8.5" or a 7.5" rear.
if it has 9c6 or 9c1 on the sticker glue to the trunk lid then it will be 8.5"
also would have larger brakes and 5 on 5" wheel bolt pattern like the trucks and station wagons |
what size motor you have?if it's not a 350ci more than likely it's a 10 bolt 7.5.
Okay Thanks For The Good Replies, Was A Big Help.
Learn how to tell the difference between 7.5" and 8.5". GM didn't seem to have any set rules on what car/engine combo got what rear end or what wheel bolt pattern. I suspect a hi-po model would get the 8.5" for sure, but some of the mid-sized turbo Buicks from the '80s got 7.5" units, so who knows for sure.
Last year I junked a couple of Buicks that illustrate my point. One was a big old '82 Park Avenue that had a 307 Olds motor, a 7.5" rear end, and the 5-on-5" wheel bolt pattern. The other was a slightly smaller '84 LeSabre, also with a 307, but it had an 8.5" rear and the 5-on-4.75" bolt pattern. |
caprice rear end
| All times are GMT -6. The time now is 08:41 AM. |
