1987 chevy blazer full size 4x4 straight gear lube ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 08:22 PM
OLDFART952
yoh guys, i have a 1987 chevy blazer full size 4x4 350 auto. gasket shot on rear end. what kinda gear lube do i fill it with ???? thanks oldfart
Old 03-16-2011, 12:47 AM
Wiki Edits: 31
80W90 in straight dino oil.. some will say 75W90 in Synthetic or semisyn and it's easier to find in synthetic so that might jive. I personally just stick with Dino grade Rotella 80W90 in my K1500 w/ 14 bolt. and I use RTV for the gasket
Old 03-16-2011, 03:47 AM
sqzbox's Avatar
My pipes are my music
Funny, My 14 bolt 1 ton rear uses LS oil.
Old 03-16-2011, 04:17 AM
Wiki Edits: 31
1 ton is a 10.5" full floater 14 bolt. Not sure if it makes a diffrence.. My '95 is spec'd for 80W90 even with the F44 option 14 bolt ( which is a 9.5" semi floater 14 bolt )... the GM fluid is just full synthetic 75W90 which the newer trucks are spec'd for
92 k15 full size blazer elec problems IWB24/7 Electrical 12 02-23-2011 08:53 PM
79 GM blazer full size with t-350 problems almandude Transmission - Rearend 3 12-12-2009 08:03 PM
Chevy 8.5" 10 bolt Gear Lube Capacity tmeyer Transmission - Rearend 17 06-19-2009 06:25 PM
5.3 ltr. Gen 3 in a 93 Blazer full size...? Bumpstick Engine 1 10-06-2006 09:06 PM
1990 Full Size Blazer Steering Column problems..tilt boneyard Buick Suspension - Brakes - Steering 5 02-08-2006 10:39 PM
