1987 Chevy shortbed 4x4 gear ratio questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2010, 06:32 PM
hello, im tim... i have an 87 chevy r-10 shortbed 4x4 with a 4 inch suspension lift, 3 inch body lift. 350 under the hood 400 turbo trans, with a *** end problem! i have 4.10 gears in the front, and ordered a 4.11 gear for the rearend on accident. the question is...will that still work?
Old 05-08-2010, 08:28 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Hey Tim, welcome to HR.com. I can't help with your problem but you should look around and keep bumping this up till you get an answer.
Post your question under the Transmissions-Rearends heading.
You could do a search on this site, too.
454 RATTLER
Old 05-08-2010, 08:37 PM
ericnova72's Avatar
More for Less Racer
Yes, it will be fine, many factory 4x4's are this way as some front diff's are not available with the exact same ratio as the rear diff, like your case of 4.11 and 4.10. I've seen 3.89 and 3.90 or 3.91, 3.07 and 3.08, 4.10 and 4.09, 3.73 and 3.70, 5.13 and 5.14, and more I can't think of at the moment.
If an axle is available with say 4.10 ratio, there is no way to make a 4.11 ratio for it in most cases due to pinion gear and ring gear sizes and tooth counts.
Old 05-08-2010, 09:26 PM
thanks
i was told one tenth of a ratio wont make a differants. i bought this truck about two monthes ago and havent even played with it yet. i use to have a 69 c10 with a 350 and loved it but lost it in bad times with the wife. talking about a nice truck. im just hoping my r10 will hold up like the c10 did
Old 05-08-2010, 10:01 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
that will be perfect, because you want the front end to be a little higher geared, (numerically lower) so when you are driving in snow or mud the front end is pulling you straight
not the rear-end pushing you sideways
Old 05-09-2010, 10:05 AM
cool
never thought of it that way makes sence
Old 05-09-2010, 07:13 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
X2 on this statement
On icy roads-----equal driving forces on the front and rear can get a bit squirrly (particularly on a truck with Locking/Freewheeling hubs). So---You do want the front going a bit faster.
Full Time GM 4x4 not to worry either----the transfer case acts like a differential.
whats my gear ratio????? 79C10 Transmission - Rearend 9 10-19-2007 03:16 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
gear ratio lizard.king Transmission - Rearend 1 01-16-2006 10:25 PM
will these numbers tell me the gear ratio? lizard.king Introduce Yourself 3 01-16-2006 08:28 PM
Gear ratio question RiceMuncherdude Transmission - Rearend 3 04-10-2003 10:45 PM
