1987 Chevy Tbi Problems
I have a 1987 Chevy 3/4 ton 4x4 that has been giving me some problems lately. AFter it warms up it starts to backfire (not loud backfire more like small pops) out the exhaust when idleing, It doesnt doesnt backfire when running down the road mainly just at idle. I put it on a computer account the check engine light was coming on after it warmed up also. Error code 44 lean, Running 44 lean in open loop, During limp mode there is no backfireing. Also during the warmup, right before the check engine light comes on you can feel a small surge of power like someone shot some ether into the throttle body then bang the check engine light comes on. Thanks for any help.
I have seen many with the same symptoms that you are having, and they have had bad fuel pumps. These engines will still run OK most of the time with lower than specification fuel pressure but at times it will lack power and have a lean condition pop at idle.
Check your fuel pressure and even if you are 1lbs low replace the fuel pump and fuel filter. Code 44 will set with a bad fuel pump. Hope this helps Steve |
fuel filter
All the replys are accurate....I have always started with the fuel filter because it is the least expensive. Code 44 sets with a bad fuel filter
Thanks for all the help fellas.
| Chevy TBI manifold with carb? | Augusto | Engine | 13 | 02-10-2007 10:16 AM |
| 90' Chevy TBI | kohle1ce | Engine | 2 | 10-18-2006 09:55 PM |
| chevy tbi experts??? | k-star | Engine | 29 | 11-24-2004 06:52 AM |
| 1986 305 chevy vs. 1987 305 chevy new style small block | mtinsley | Engine | 2 | 08-22-2003 11:55 AM |
| 89 Chevy P.U. TBI ????? | catdad2u | Engine | 1 | 11-12-2002 02:52 PM |
