1987 IROC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2003, 12:11 PM
Post 1987 IROC
No power. When I used to turn the ignition to the on position, the fuel pump in the tank would run 2 - 3 seconds like it was supposed to do. Now when I turn the ignition switch to the on position, the pump does not run. When I start the engine the pumps runs all the time. I have replaced the mechanical pump on the engine and changed the carb filter. Anything over 1/2 throttle, the engine falls down until I back off the throttle and it picks up again. Since the pump is getting power I assume the problem is a sensor. Any help would sure be appriciated.
Old 02-12-2003, 01:17 PM
Post
You're going to have to clear some things up here. You start out talking about hearing the fuel pump run when you turn the key to the "ON" which would indicate a fuel injected car, but then you started talking about the mechanical pump and the carb filter. A mechanical pump would indicate a non-fuel injected engine. What filter do you mean when you say "carb filter"?
Old 02-12-2003, 01:24 PM
Post
I am confused, if the pump in the tank is working that means (to me) that the car was once an injected car and is now a carb car at any rate sounds like mabey the seconadarys are opening but the metering rods are not lifting if its a QJ.good luck.
Old 02-12-2003, 09:08 PM
Lightbulb
Sounds like the fuel pump relay switch to me. Change it and the electric pump should work fine.
Old 02-14-2003, 08:49 AM
Post
I would be suspicious of the electric pump, but I'm not very familiar with your setup so I can't offer too much help.
You might try asking the guys <a href="http://www.f-body.com/forum.cgi" target="_blank">here</a> about it. There are some very sharp guys there who are very helpful.
