1987 R-20 454 with 502 roller cam running rich - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 08:07 AM
I have a 454 with a 502 roller cam out of a 1987 r-20 chevy pick-up that I put in an 1985 chevy c-30. Just got this thing going and it is running way rich. I installed a new oxygen sensor and this is fuel injected so I have idea as to why it would run this way. I do have a vacuum line that is cracked that runs from the EGR valve to the EGR solenoid check valve, I would not think could be my entire probelm, I taped it up and it still runs pig rich, well rich enough for the motor not to respond and to blow black smoke like a mildly turned up diesel. The service engine light comes on and goes off at random, assuming this could be considered the check engine light in 1987 on obd1 system.
454 cam talk roller/non ekacpuc Engine 24 06-07-2011 10:47 PM
454 roller Cam Recommendation saphunt2r Engine 3 03-23-2011 09:50 PM
trying to get my 454 running with new cam 85 k5 mud truck Engine 21 06-01-2009 05:59 AM
Running a Roller Cam on the Street - Will it Eventually Fail? leejoy Engine 20 12-07-2007 12:10 PM
502 cu in Blown - Question on running too rich? firstgear Engine 10 12-07-2007 11:42 AM
