1987 S10 Blazer doesn't start - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-05-2004, 07:50 PM
Hi,
I have no dash lights. nothing no ignition. able to crank from jumping the starter through soleniod. what could be the problem? I I have wired direct battery positive to the IGN / ACC fuse block and lights come on. accessories start to work but still no ignition when I try to start. Please help me!! I need this truck to run!!ASAp
Old 12-05-2004, 07:59 PM
poncho62's Avatar
Wiki Edits: 5
The main accessory wire is connected to the large post on the solenoid. It has probably corroded off. Reattach it and you should be fine.
