1987 v10 surburban 350 tbi/electricial issues? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2010, 05:24 PM
I have an oem without smog pump truck. One day 10 days ago i had a lope in idle read up on it replaced EGR- problem resolved ran fine for 5 days engine would not start just cranked found a fuse blown on ecm-I, talked to friends sid fuel pump (have heard of fuel pump blowing a fuse they told me) replaced fuel pump still would not start, still blew fuse would not start, found dead short in wire to old smog pump was grounding out causing fuse to blow on ecm-I. truck ran approximately 32 miles fine. Next morning let idle 10 min. go to take off less than i mile engine starts to bog more and more than dies. Turned key to start fires right up go to drive distance gets shorter repeats it self bogs and dies. it repeats the same conditions. Haven't found problem one friend states its in these sensors yet no codes and another states if a fuel pump has a slight air leak in hose or the seal to sending unit is not completely sealed to tank it could cause this. I really need more opinions/answers i haven't re dropped the tank yet but i thought i would get on here first and ask . Thanks Donna
Old 10-21-2010, 06:26 PM
LATECH's Avatar
Dropping the fuel tank dindt fix it the first time , why bother dropping it again?
Have you changed the fuel filter? Could be plugged.
Old 10-21-2010, 08:55 PM
did replace fuel filter no change, i was told if there is the slightest air getting into the system from a seal or hose it could create this problem was going to check seal sending unit to tank. also it was not the fuel pump really it was a dead short blowing the ECM-I fuse. But with cranking issue non start and a blown fuse they thought the fuse was blown per the fuel pump so the pump was changed out but it was actually a dead short found in wiring elsewhere when that was found and fixed it started and ran 32 miles without trouble. the next day it started these other symptoms as listed in first tread.
Timing issues with 1974 sbc 350 stfinney Engine 24 08-09-2010 07:14 PM
1987 tbi to a 1997 350 sfi vortec g.b. Electrical 0 10-19-2003 05:32 PM
Chevy 350 Timing issues Dans83Olds Engine 3 09-04-2003 02:22 AM
exhaust and intake valve clearance for a 1987 350 C 10 jpeterson Engine 0 02-20-2003 08:59 AM
adapting early sbc intake manifold to 1987 350 heads steve curtis Engine 1 06-13-2002 02:56 AM
