Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1988 318 not cranking over
Old 01-07-2013, 01:25 PM
crownver crownver is offline
My guess is you're leaking enough coolant (or oil I guess) into 1 or more cylinders to raise the static pressure high enough to prevent the starter from turning the motor. Once you turn it over by hand a couple of times, you clear enough of it to start it. The rest burns off and it's good until it sits and leaks more into the cylinder.
