1988 318 roller camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2012, 12:32 PM
Well I'm not sure as to what camshaft to install in my 1988 318 roller camshaft block.I have A edlebrock performer intake also edlebrock 600cfm carb use ing hypertech pistons w chrome rings.I also am using HEI distribitor .staying with stock exh manifolds w duel exh. What would be a good roller camshaft? I have 302 swirl port heads am doing light port&polish job on.I don't want a radical cam that I have to change springs rocker arms ect..Something with low rpm torque. Good mpg Any input helpful
Old 11-17-2012, 02:04 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
My best advice would be to get on the phone and talk with a tech at your favorite cam grinder.....
Old 11-17-2012, 02:46 PM
Any 318 head before the magnums arent worth the work. You want power for a daily vehicle, not racing, right. If you trust me, Get a set of magnums for a 318. They have the larger valves and install beehive springs from a series 2 GM v6. They drop on. This combination with the original cam will give you a large power/ torque increase from a small cam. Even a stock roller. Similar to a vortec heads swap on a 350. Hit the yard before it really starts to snow. You could probably get the magnum heads and GM beehive springs for under 250, and just clean them up with new 2.2L umbrella valve seals.
Read one for GM springs
http://board.moparts.org/ubbthreads/...=5#Post3134434
whats needed
http://board.moparts.org/ubbthreads/...=16#Post851383
flow
http://board.moparts.org/ubbthreads/...=18#Post366847
Best head mod for a low budget mopar . Yes I did it. The good? ported 051 swirls flow about 175 on a good day.
Old 11-17-2012, 03:02 PM
BOBCRMAN@aol.com's Avatar
Also be aware that production Magnum 318-360 heads are crack prone (end cyl between valves.). Beware of junkyard heads.
Old 11-17-2012, 03:33 PM
Okay and... Most heads are crack prone. There are reconditioned fluxed magnums under 279 pr on the bay.
More pearls one of the best Mopar ignitions is the stock HEI with a Gm 4 pin module. Bullet proof. Loose all the wires and boxes.
A pic of how easy and clean.
Old 11-17-2012, 05:22 PM
Comp Cams 264HR-12 is an awesome cam for a 318.Also the 302 heads are good flowing pieces.I have used this cam in two pre magnum roller 360's and love em.
Old 11-17-2012, 05:24 PM
BTW the specs for this cam are 210/220-480/480 on a 112 lsa.If you need springs use 901-16.
Old 11-17-2012, 06:40 PM
302's and 051's have the swirl and the closed chamber , but are not good performers. These are not going to perform any better at that level than 915/587/596/974 open type. The runners intake side are less than 130cc. Do you realize the potential of that small a runner? They flow 150cfm at .5 lift stock. A simple Magnum swap is a great way to maximize a mild build. Easy 30-50 hp over a lower wider torque band.
The oe magnums are 172cc and flow 210cfm , the chamber is 64cc so you will like to mill it.
I cant suggest any cam. Not without gear car weight stall,,,you get it.
Old 11-17-2012, 07:40 PM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
I'm liking this thread already.Please do keep the posts coming.
Old 11-18-2012, 06:18 AM
I'm only giving advice about what I know to be facts.I know there are those of us who feel they must "Educate" us about every cc of flow and all the other E=Mc squared bull but I KNOW this combo will work.
1988 Dodge ram 318 fuel injection to carb converstion Hobodave Hotrodding Basics 5 11-02-2012 04:45 AM
318 Poly Roller Rockers Soon? Abomination Engine 0 11-25-2008 07:45 PM
1988 chrysler 318 brian berwick Engine 1 12-23-2007 10:56 AM
New 318 Poly Roller Rockers!! Abomination Engine 0 03-21-2007 07:16 AM
plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? tiresmoke55 Engine 20 05-24-2006 01:51 AM
