1988 700r4 lockup question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2007, 07:54 PM
Last journal entry: my Burb
will it hurt my trans if i put a switch in line for the lockup converter ? like when im running in town i can keep it off, but if i am on the highway i can turn it on ? and if so what wire would i break ?
thanks
Old 03-31-2007, 07:30 PM
No it won't hurt any thing, in fact it is a good thing in view of the recent gas prices. I have used a dash mounted O/D switch for years on 3 different cars that had 700r4's, 1 with a manual shift valve body installed. On 1 car I installed a B+M O/D lock in lock out system so I can select the speed that O/D engages. If you race the car with the B+M wired in make sure you disconnect it before the race or it will put you in O/D at about 85 MPH even with the selector at max.
Good Luck, Dave Johnson
Old 03-31-2007, 07:35 PM
Thanks beach10222
does anyone know which wire i need to put on a switch ?
Old 04-10-2007, 08:30 PM
im amazed no one knows,
Old 04-10-2007, 08:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yep , me too.
the 12 volt power wire at the trans would work
700r4 question Danscam Transmission - Rearend 4 02-21-2007 09:42 AM
700r4 trans question Tim Denoyer Transmission - Rearend 9 02-18-2007 12:13 AM
700r4 lockup runn141 Transmission - Rearend 3 09-06-2006 07:40 AM
For what it's worth, 2-3 lockup 700R4 good for 1 MPG LanceM Transmission - Rearend 2 06-22-2006 05:43 PM
700r4 "stupid" question... mtjunk67 Transmission - Rearend 3 10-05-2005 10:42 PM
