1988 camaro z28 automatic - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2011, 03:16 PM
My 88 camaro 350 tach redlines at 35mph the car will go faster still but it will be pinned at 800 rpms the oil guage does not read properly either all other gauges work fine pls help?
Old 10-02-2011, 09:43 PM
DoubleVision's Avatar
The tach likely has a poor ground as for the oil gauge it needs a new sending unit which will be right beside the distributor, takes about 10 minutes to replace it. Make sure when you go for a sending unit you tell them it`s for a gauge and not a idiot light.
Harness Camaro 1986 TPI to 1988 TPI Parisienne70 Electrical 5 11-24-2008 09:59 PM
Help! 1988 Camaro Relays..need Identification boneyard Buick Engine 2 07-08-2005 06:03 PM
1988 camaro 2.8v6 81FIREBIRDESPRIT Engine 3 04-10-2005 03:06 PM
1988 camaro 700r4 81FIREBIRDESPRIT Transmission - Rearend 2 04-10-2005 12:02 AM
1988 Camaro RS?? Pony General Rodding Tech 7 05-07-2004 09:30 PM
