1988 camaro z28 automatic
My 1988 camaro 350 tpi tachs at 800 rpms at low speeds such a 35 mph the car will go faster but the tach pins the needle. Also my temp gauge does not work properly when you turn the ignition off and on the temp gauge bounces up and down it also it has a check engine light at idle but shuts off when you put the car in drive and press the gas pls help.
Last edited by money3412; 10-02-2011 at 04:06 PM. Reason: make it more understandable. |
Not quite sure what you are trying to say. Your post isnt worded in a fashion that Is coherent for assisting you as I cannot understand it.
Please re post and proofread it so as to be sure it can be read and comprehended |
My 1988 z28 camaro
Is that better can you understand my question now? pls just let me know?
My 1988 z28 camaro
I want to know what is causing it to happen please help?
Based on what I can make out of the description, it sounds like the car is not shifting.
| 1988 camaro z28 automatic | money3412 | Engine | 1 | 10-02-2011 08:43 PM |
| Harness Camaro 1986 TPI to 1988 TPI | Parisienne70 | Electrical | 5 | 11-24-2008 08:59 PM |
| 1988 camaro 2.8v6 | 81FIREBIRDESPRIT | Engine | 3 | 04-10-2005 02:06 PM |
| 1988 camaro 700r4 | 81FIREBIRDESPRIT | Transmission - Rearend | 2 | 04-09-2005 11:02 PM |
| 1988 Camaro RS?? | Pony | General Rodding Tech | 7 | 05-07-2004 08:30 PM |
