1988 chevy 2500 rebuilt 700r4 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 04:55 PM
so recently installed a rebuild 700r4 from a company in AZ american carz. Transmission has been in truck for approx 200-250 miles, tv adjust properly and line pressure checked by trans shop locally so to my knowledge and that of the shop i went to all was well, day before last took truck down the road and it took a while to build pressure and go into gear, figured low on fluid parked the truck went through the gears than checked fluid level right on the money, start truck up this afternoon and attempt to move it and no gears at all, checked for fluid ouput and it streams out fine from the cooler line, does not smell burnt but fluid is a dark purple in color. ideas? i know 700r4 are a difficult tranny to set up and fairly tempramental but my last one was problem free for 230,000 miles! any input advice or otherwise is appreciated
Old 06-24-2010, 04:59 PM
also truck is a 4x4 1988 chevy 2500 single cab, engine was converted to a carb'd 305 punched to 350.
Old 06-24-2010, 08:30 PM
Rexnfx's Avatar
If its recently rebuilt. Why not take it back for warrenty repairs? I'm sure it will have to come back out. Good luck
How do i look up a rebuilt id tag number chevy 327? randyhemi Engine 1 10-19-2008 11:39 AM
700R4 fit behind a chevy 235 straight 6? panamracer Engine 3 01-02-2007 07:24 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
1988 Chevy Wagon Lowering porterville Suspension - Brakes - Steering 1 03-18-2006 02:05 AM
700r4 help-any chevy guys? briansansone Transmission - Rearend 4 02-24-2006 01:30 PM
