1988 chevy 5.7runs fine but has werid knock in bottom - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2011, 11:08 PM
hi i have just put in a new 350tbi in my 88 stepside the motor came out of a 90 gmc 4x4 it ran great was sitting around for a few months , it ran fine but i put it in my truck and it runs good but has a knock and like a pinging sounds from the bottom i have took off the fly wheel to see if it was cracked but to find nothing it runs great no power loss do sent smoke runs great just this knocking sound from the bottom near the oil pan please help me out this is my third motor that s been nothing but problems thanks
Old 06-22-2011, 11:19 PM
badknuckles's Avatar
you talkin to me?
since you took out the trans/flywheel, did you run the motor without the trans hooked up?
Old 06-22-2011, 11:24 PM
that was my next step what would u think it is?
Old 06-22-2011, 11:56 PM
you talkin to me?
There are only a couple things if it is bottom end. Once the trans is out of the equation, that only leaves a rod
Chevy 350 bottom end knock peetyweet Engine 5 02-04-2011 05:58 AM
Grit - how fine is too fine for adhesion? cboy Body - Exterior 41 06-28-2009 05:20 PM
700r4 wont shift out of 1 works fine in rev 1988 gmc sub chass Transmission - Rearend 7 08-03-2006 09:46 AM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 01:30 AM
some sort of bottom end knock?? v8s10 Engine 3 07-14-2003 06:39 PM
