1988 chevy c1500 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2011, 08:19 PM
I have an 88 chevy c1500 and it's been skipping when I get up to 60 mph and it jumps back into drive then back into overdrive so I put a tune up on it thinking it would help but it still does it and I am just wondering y it's doin that any suggestions would help thanks
Old 10-01-2011, 08:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title to reflect what your question subject is.
Old 10-16-2011, 09:08 AM
What do you mean falling out of lock up? It's like when you get up to 55 mph it's like it goes down a gear then jumps back into overdrive
Old 10-17-2011, 06:40 AM
SSedan64's Avatar
The 700R4/4L60 Trans uses a Lockup TC/TorqueConverter, it has an internal Clutch. This locks the CrankShaft & Trans together 1:1 and drops the Engine rpm an extra 200-300rpm when cruising.
Does your engine rpm cycle about this amount or is it cycling from 3rd to 4th to 3rd gear?
A bad TCC Solenoid, Brake Light switch or TCC can cause this.
TCC = TorqueConverterClutch.
Old 10-19-2011, 06:56 AM
It goes from 3rd to 4th and back and forth as long as I am driving
Old 10-19-2011, 07:12 AM
SSedan64's Avatar
Can be tough to diagnose. A Pressure Test would help figure out what's going on.
A few things that could cause this:
Pump problem, low pressure.
TV/ThrottleValve binding/sticking.
Governor problem.
4th gear Servo problem.
Pr. Gauge example >> http://www.sjdiscounttools.com/atd-5550.html Amazon has good prices on these and many have Free S/H.
tcc problems in 1990 c1500 liljohnalan Transmission - Rearend 5 01-08-2011 07:44 AM
1988' Crown Vic, 5.0 AOD problems Bmojo214 Transmission - Rearend 5 12-16-2010 10:15 PM
1988 chevy 2500 rebuilt 700r4 problems 88BIGchevy Transmission - Rearend 2 06-24-2010 08:30 PM
1996 Chevy c1500 4L60e problems osiris419 Transmission - Rearend 5 10-05-2009 05:17 PM
89 c1500 700r4 shift problems or toast? slammedchevy1500 Transmission - Rearend 12 12-30-2008 09:34 AM
