1988 Dodge ram 318 fuel injection to carb converstion
I'm in process of tossing my fuel injection.My 1988 318 block is roller cam am ordering a HEI distribitor with built in brain.Air gap 4bl intake.500cfm carter carb.A fuel pressure reg.Staying with FI fuel pump am wireing fuel pump into oil pressure sw.for safety automatic on-off.Im also porting polishing my 302 swirl port heads.Using my 318 exhaust manifold.My question is what CFM carb should I get?And should I get a RV roller cam and what lift?This is my work truck but want dependable daily driver with more mpg and horsepower not a hotrod.Any help appreciated !
Carb
I was asking should I buy a 500 CFM or larger?Also I would like to replace my OEM roller cam for a RV style roller cam.If there is such a RV roller cam.Most roller cams seem extreme requiring spring change ect.
I have had two of these engines although they were 360's.The best cam for them is the Comp HR264-12.It has 210/220 duration and .480/.480 lift on a 112 lsa.These things pull like a freight train!!
Thanks eggman what is a good CFM for carb size
600 will be fine.Engines only use what they need that is why Qjets were 750-800 cfm even on 305's.I would put an Edelbrock 1406 on it and call it done.
| 318 5.2 V8 Dodge Ram 1996 | PM123 | Engine | 2 | 09-30-2011 11:40 AM |
| 1988 chevy Fuel Injection Problem | 52Ford | Electrical | 11 | 10-26-2006 05:28 PM |
| carb vs.fuel injection. | firebirdames | Introduce Yourself | 1 | 07-27-2004 10:32 AM |
| Carb or fuel injection | dragon wagon | Engine | 3 | 03-05-2004 02:02 AM |
