1988 GMC Sierra transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2008, 06:42 AM
my transmission seems to go every time i do a burn out im lookin for ideas on how to either build one that can go to hell and back or what i should put in. my truck is an 88 gmc sierra with a 355 under the hood.
Old 12-26-2008, 06:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Give us a clue on what transmission you are running now.
Your current transmission burns up each time you do a burn out? Is this on the street or drag strip ?
Is this 355 engine really build up to high power?
Old 12-26-2008, 07:07 AM
repy to last
well it dont go every time that was a little exaggeration but it goes often but it is on street.# Base engine - Basic engine with intake manifold and valve covers
# Dress engine - Complete engine including induction, ignition, fuel pump and other accessories
Block:
# 4-bolt main block
# Passenger side dipstick
# Square and parallel decked
# Align honed main bearing bore
# Cylinders are sonic tested for thickness
# Cylinders honed on a computer controlled machine to within .0002'' straightness and roundness
Rotating Assembly:
# SCAT 3.48'' cast crankshaft (2 piece rear main seal)
# SCAT 5.7'' I-beam rods
# Keith Black hypereutectic pistons
# Hastings Moly rings
# Clevite bearings
# Internally balanced rotating assembly
# Melling high volume oil pump
# Heavy duty double roller timing set
Cylinder Heads:
# Dart aluminum heads
# Hardened retainers and 1.437'' diameter valve springs
# 2.02'' swirl polished intake valves
# 1.60'' swirl polished exhaust valves
# Hardened pushrods
Camshaft Specs:
# Hydraulic Flat Tappet
# Duration @ .050'' Lift: 224 Intake / 230 Exhaust
# Lift: .480'' Intake / .486'' Exhaust
# Lobe Separation: 110�
Other Features:
# Professional Products dual-plane satin aluminum intake
# Signature Series aluminum valve covers
# Chrome timing cover
# New 5-quart oil pan
# Brass freeze plugs
# Professional Products Balancer
# 9.5:1 compression
Dress Model Adds:
# Edelbrock 600cfm Carburetor
# Edelbrock water pump
# Edelbrock fuel pump
# MSD distributor
# MSD coil
# MSD spark plug wires
Horsepower: 360
Torque: 380
this is my motor except mine is efi instead of a carb
Old 12-26-2008, 07:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
*SNIP *
Horsepower: 360
Torque: 380
I am still not seeing the transmission listed.
Is it a 4L60 or a t-350 or a t-400 transmission?
Old 12-26-2008, 07:36 AM
it is a t-350
Old 12-26-2008, 10:27 AM
SSedan64's Avatar
Check out Jakeshoe's tH350 buildup located at the top of the trans/rearend section. I think His build is said to be good for 600 or so HP , haven't read it in awhile. I think Jake mentioned when doing a burnout to have the shifter in 2nd to keep from hurting the trans, can remember exactly. Guess I need to read it again also.
http://www.hotrodders.com/forum/th35...ch-145361.html
Old 12-27-2008, 04:26 PM
thanks for the help
1988 GMC No FWD 68NovaSS Transmission - Rearend 16 03-11-2008 07:45 PM
what type of trans in 1988 GMC Jimmy?? kuhn-77 Transmission - Rearend 1 09-26-2007 05:03 AM
Which muffler 2000 GMC sierra 5.3 85CHEVY Engine 4 12-09-2004 08:46 PM
3 Speed Automatic Transmission Problems - 93 Pontiac Sunbird JOEMAMA Transmission - Rearend 4 04-17-2003 06:35 AM
Transmission problems kemo Transmission - Rearend 2 11-21-2002 01:48 PM
