1988 Jeep Cherokee Battery Charging Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2009, 06:09 PM
First of all I appreciate any help anyone can provide. A thanks in advance by the way.
I know the battery is good, so the first thing I went to since it wasn't charging is the alternator.
I changed it out, making sure all the wires were in the correct place, but the battery still isn't holding a charge.
Anyone have any suggestions?
Old 11-26-2009, 07:00 PM
Some other information... the alternator has been tested.
The power has been tested on the wired and are as follows...
The big wire that bolts on has power
The yellow wire has power
the tanish brown wire has no power
Old 11-29-2009, 09:09 AM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
You say that the battery "is not holding a charge"...
Here's what I would do to troubleshoot initially:
Get your hands on a voltmeter and check the battery with the engine running. You should see around 14 volts at the battery terminals with the engine running. With everything shut off you should still see over 12.6 at the battery.
Turn some headlights and the heater blower etc on to load the system, you should still see 14 volts or so at the battery. If not, then the charging system is not up to par.
If the charging system is doing it's thing then your battery is not holding a charge or something in the electrical system is constantly loading or draining the charge - that's another matter.
Old 12-03-2009, 01:57 PM
fast68's Avatar
likes chevy trucks & boobies
we have an 89 and it was going low also over time,. not holdin voltage. i checked the back of the alt with a screwdriver while it was running to see if it was magnetic and it was and the 12v to it was good also but it still ended up that the alt was bad, diode or something they said
it confused me.
made no sense
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Faulty battery? TwistedTrbl Electrical 18 12-04-2005 06:20 PM
alternator not charging battery again 73chevyhelp Electrical 2 10-18-2004 11:58 PM
Charging problem Adrenaline_Fiend Electrical 5 04-20-2003 12:05 PM
Charging problem rflud Electrical 2 02-12-2003 05:56 PM
