1988 K1500 - 700r4 tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2007, 03:08 PM
JRH JRH is offline
I have a shifting problem
I have a 1988 chevy k1500 with a 700R4 we just rebuilt it and put it back in the truck. It shifts fine for about 10 min intil the trucks gets warmed up but after that it shifts good from first to second but it wont shift from second to third. I was just need to know if there is a sensor or something that might of went bad or if i need to adjust something
Old 04-20-2007, 03:35 PM
BigDawgsEatFirst's Avatar
400SBC4Life
you might have to start a new thread for your post
to get an answer
Old 04-20-2007, 06:16 PM
Crosley's Avatar
Wiki Edits: 1659
cut sealing ring , sticky 2-3 shift valves , too much clearance in the 3-4 clutch pack.
No sensor problem here , all mechanical
