I would try to get some graphite lube on the cable from where it comes out of the firewall to the bracket on the intake.
i guess I should get a new cable!! it seems ok but it is 20 years old
Why would the truck accelerate faster then what I was going if the cable just needed to be lubed it dosn't look fared can't tell how it is inside the covering though. I was going 55mph took my foot off the gas pedal and the truck accelerated to 80 mph before I turned the key off. Last edited by watchdude1; 03-08-2010 at 07:07 PM. |
I had the same issue on a 79 chevy luv, I had narrowed it down to a malfunctioning idle control solenoid, turns out it was shorting out and pushing the plunger all the way out, which in turn was acting like it was floored. Good thing the truck was so gutless it slowly started speeding up. Not sure if yours has one, but it's worth a shot.
I have been following this cars speeding up with peoples foot of the gas problem and for the life me can't see a truck or car doing this with a cable throttle. If its not computer related in some way. I will be the first to admit I know little about computer controls in cars BUT I AN'T NEVER had a throttle pull its self.And a floor mat would not make the peddle go down. It mite cause it to hang IF you had floored it or at lest accreted to blend in or some such. but seems to me that it would not get any faster then what you had pushed it down.
Just my ramblings on this.OLDROD PS. Just a thought do you have cruise control? |
Is this the same truck with the mysterious brake pedal dropping to the floor syndrome and bucking issue?
Time to ditch that thing. Seriously, is there a vacuum leak, dislodged throttle plate in the throttle body or stuck linkage? My guess is there is a vacuum leak between the throttle body and the engine or the idle air bypass solenoid is loose. Since this truck has had an engine change there are a hundred things that could of been damaged in the swap including the intake system coming loose. Time to spend some time under the hood and check all the basics before we blame Toyota for computer problems and unintended acceleration.
Outlawed tunes from outlawed pipes |
OLDROD |
If it is sucking air somewhere it can cause RPM run away.
Throttle position sensor should not cause this type of scenario.
Artificial Intelligence is no match for Natural Stupidity Chet |
look at the brake booster. I had a '92 ford Ranger 4x4, that liked to 'blow up' the check valve on the booster, and when it did, it had a 2-3k idle and it would cruise at 40 MPH in 3rd w/o any gas pedal. one time, it only cracked so it was intermittantly getting the high idle
| Toyota accelerator pedal problem... | awbazar | Hotrodders' Lounge | 143 | 03-18-2010 09:57 AM |
| 1988 Toyota pickup bucking at 55 mph? | watchdude1 | Engine | 7 | 11-05-2009 06:36 PM |
| Mating FWD Toyota Transmission to GM 60 Degree V6 Motor | dmc12mk3 | Transmission - Rearend | 3 | 11-29-2004 02:17 PM |
| M-22 Transmission in a toyota?? | traub83 | Transmission - Rearend | 0 | 05-27-2004 08:10 PM |
| Toyota 5-speed | Greg55_99 | Transmission - Rearend | 3 | 03-22-2003 09:56 AM |
