Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1989 4l60( 700r4) shifts from 2nd to neutral
Old 12-04-2005, 05:33 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
Had the same problem. It's not neutral, there not enough fluid to operate the servo.
When I installed my trans I filled it with fluid. Running Hot.
Apparently I wasn't very careful because when I had the shifting problem you describe I rechecked the fluid.
When I added (1-1/2) quarts, it shifted OK.
Check it out.
vicrod
