1989-90 Corvette's L98 TPI HP-CR doubts
Let's see this 89 v/s 90 Corvette specs both TPI :
1989 : Compression Ratio 9.5:1 Horsepower 245 hp @ 4,300 rpm (coupe w/ 3.07:1 axle) 240 hp (convert.) Torque 340 lb-ft @ 3,200 rpm 1990 : Compression Ratio 10.25:1 Horsepower 250 hp @ 4,400 rpm (coupe) 245 hp @ 4,000 rpm (convert.) Torque 350 lb-ft @ 3,200 rpm (coupe) 345 lb-ft @ 3,200 rpm (convert.) On 1990 the L98 got flat top pistons and the compression ratio increased from 9.5 :1 to 10.25:1 How come the extra compression added only 5 HP ?????? i read that they "pussified" the cam to give the engines not too much power ....and that's why the 5 HP increase only.... Is this true ? i cant believe that !! Did GM follow certain standards ? thanks |
From the specs I gather the earlier L98s had 9.5:1 compression and the 1991 recieved 10:1. only a half point in compression is worth very little in means of power, a half point raise would give it about five more horses.
You can look at the year specs here: http://www.100megsfree4.com/corvette/1990/vet91.htm |
A full point of compression is only worth about 3-4% power, so I think 5 hp is actually a nice gain from such a little increase in compression
| All times are GMT -6. The time now is 08:21 AM. |
