Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1989-90 Corvette's L98 TPI HP-CR doubts
Old 02-22-2008, 08:36 AM
Calderone Calderone is offline
Let's see this 89 v/s 90 Corvette specs both TPI :
1989 :
Compression Ratio 9.5:1
Horsepower 245 hp @ 4,300 rpm (coupe w/ 3.07:1 axle)
240 hp (convert.)
Torque 340 lb-ft @ 3,200 rpm
1990 :
Compression Ratio 10.25:1
Horsepower 250 hp @ 4,400 rpm (coupe)
245 hp @ 4,000 rpm (convert.)
Torque 350 lb-ft @ 3,200 rpm (coupe)
345 lb-ft @ 3,200 rpm (convert.)
On 1990 the L98 got flat top pistons and the compression ratio increased from 9.5 :1 to 10.25:1
How come the extra compression added only 5 HP ??????
i read that they "pussified" the cam to give the engines
not too much power ....and that's why the 5 HP increase only....
Is this true ?
i cant believe that !! Did GM follow certain standards ?
thanks
