1989 Beretta GT - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2002, 04:17 PM
Question 1989 Beretta GT
I have a 2.8 automatic that starts to buck and stalls out after fifteen to thirty minutes running and will not start for an hour or more. Does anyone have any ideas to what this is.
Once it stalls I can sometimes get it started, but when put in gear it will stall out. I've tacked the car up to three grand and dumped it into gear to get it to move so that I could make it home, but when it goes down around a grand rpm it will start to buck.
Thanks
[ September 29, 2002: Message edited by: jacropley ]</p>
Old 09-29-2002, 04:34 PM
roys63's Avatar
Post
May be the intank fuel pump ? can you hear the pump running when trying to start after it shuts down? or is the battery dead? And you have to jump start to get running again if so you need a alt.
[ September 29, 2002: Message edited by: roys63 ]
[ September 29, 2002: Message edited by: roys63 ]</p>
Old 09-29-2002, 04:53 PM
Big Mac's Avatar
Lightbulb
After it stalls, will it still crank over but just not start or will it not even turn over?
Usually if an engine quits after warming up and then runs again when it is cooled down it will be a bad coil. On that car you have three coils mounted to a module, and each coil runs two cyls. If you check your spark plug wires for a weak spark at the spark plug you will be able to narrow down which coil is bad. Make sure you check this when the car is hot and won't start. And you might not find a plug that doesn't spark it might just be a weak yellow spark. (spark should be blue)
Real Rods are Built Not Bought!
Old 09-29-2002, 04:54 PM
Big Mac's Avatar
Lightbulb
