1989 C1500 Drivability Problem(Surge/Stutter) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #16 (permalink)
Old 01-04-2012, 08:55 PM
Race The Truck
Last journal entry: Son's Truck
Originally Posted by 40 grey
Thanks to all for their help and suggestions. After further testing and retesting, the EGR valve was found to be intermitantly sticking open when solenoid commanded it open(cruise over 40mph). Oddly enough it would manually test okay, held vacuum, and pintle moved freely off the truck. When on the truck it would sometimes not seat or open freely after it was hot. New one(ac-delco) is coming tomorrow. Hopefully this is the problem. ---
---BTW, it ran pretty good with automatic ecm and prom. Low idle(500rpm), and shift light on steady were only observed problems.-----
That is what I was thinking was wrong! But with out the 3 shop manuals I don't know how you new everything was working correctly? Not unless you have the 3 shop manuals? Also here is a good site for trucks and mods www.fullsizechevy.com
Craig
  #17 (permalink)
Old 01-04-2012, 09:06 PM
40 grey's Avatar
Dusty mayhem
I do not own the GM manuals. I do have an old, well used and trusty Motors manual. But I do have access to the GM manuals through work. Through these and an old Snap-on scanner most things can be observed/tested, even if it is done crudely! I have a fair amount of experience with junk and low budgets.
  #18 (permalink)
Old 01-04-2012, 10:34 PM
Race The Truck
Thats good you have manuals because with out them is just guessing I found that out the hard way! Go to the web site one of the best for chevy trucks!
  #19 (permalink)
Old 01-07-2012, 08:42 PM
40 grey's Avatar
Dusty mayhem
UPDATE: EGR valve finally showed up and was installed today. Made sure passages were clean(it was). Night and day difference. Problem is completely gone and truck is smooth again! Thanks to all who offered help, it never hurts to have more info.
Recent Modern Electronic Engines posts with photos
1989 to 1998 Chevy C1500 Sidestep Engine Swap. 89SideStepMan Engine 8 09-13-2010 06:45 PM
1990 Chev C1500 Starting problem bluecollarpunk Engine 2 06-12-2009 12:26 AM
drivability problem, SBC 04SilveradoMykk Engine 3 10-08-2008 08:04 PM
1989 SBC 5.7 (TBI) Problem with rebuild. gandl2123 Engine 8 06-06-2007 08:51 PM
surge problem agb1758 Hotrodders' Lounge 1 06-16-2002 06:03 PM
