Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-08-2005, 04:49 AM
mike40sm2 mike40sm2 is offline
1989 camaro 5.7 Tpi engine experts needed
Hi
Wonder if anyone can help have a 1989 camaro which I am doing up but have a big problem she starts and drives great for about 20 mile then when I pull up the engine struggles to tick over try to rev up but its as if she not getting fuel have tried new filter new plugs rota and cap all codes are fine.
If I sit there for a few minutes she will re/start and rev but then after a few minutes will do it again if I get her home and leave overnight she will again do about 15/20 miles then play up can anybody help don't know where to go next? oh also have tried new coil!
Old 10-08-2005, 06:16 AM
RCastle's Avatar
RCastle RCastle is offline
Come Home Safe Soldier
re: 1989 camaro 5.7 Tpi engine experts needed
Try a pressure regulator on the fuel rail.
Just got an 87 IROC with the TPI motor,the guy was telling me the regulator was bad and it was doing the same thing as what you described.They replaced the reg. and it worked fine. Until the ECM crashed on it.Guess that is why we only gave $350.00 for it.
Last edited by RCastle : 10-08-2005 at 06:17 AM. Reason: No such thing as a "fregulator"
Old 10-08-2005, 08:19 AM
gizmo-1948 gizmo-1948 is offline
Check your fuel tank cap--make sure the vent isn't restricted. Even tho its a closed loop system--the tank still needs to vent.
Old 10-08-2005, 02:43 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
could be fuel pump puking out.... seen them do just exactly that.
Old 10-08-2005, 03:44 PM
badknuckles's Avatar
badknuckles badknuckles is offline
you talkin to me?
ah tpi
i have had problems with the regulator and ignition modules.
my old firebird would miss after about 2hrs driving i replaced the module and it was fine...
lots of things could be wrong with a 3rd gen f body
Old 10-09-2005, 07:06 PM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
FI Young Gunner - Moderator
 Siggy_Freud's barnstar
Have your ignition module tested. Have them test is 12+ times to get it nice and hot and see how it holds up.
Look for any coorilation other than time as to when it starts to fail (especially temperature). Does it do it at any throttle position? You could really use a scanner to help determine what the cause is. Almost a MUST for diagnosing FI problems.
Or if you have a laptop you can buy a cable that will plug your OBD1 into the laptop. Then all you need is a software program which is free .
1997 BMW M3 - 3.2litre Inline 6 cylinder
Old 10-10-2005, 03:56 AM
Dizturbed One's Avatar
Dizturbed One Dizturbed One is offline
understatement of the year
i hate my 92 Camaro
but I love it so much
lol
I'd be looking for other variables that aren't so "variable" like someone else said... Engine temp for one... The temperature gauges on these cars are crappy as all hell too, and rarely ever read closer than 15 or 20 degree's off from what it really is.
Not hardly working at all is the more common case.
Could be ECU, but I'm betting it's the fuel pump like someone else said. Sounds like it's burning out... Which is why it lasts awhile when the car hasn't been ran for awhile. You can let it "rest" so the heat dissipates and it will work for awhile, but once it heats up it just dies...
The power window motor on my passenger side does that exact same thing. lol
Old 10-31-2005, 07:53 PM
JAR37FORD JAR37FORD is offline
Injector Problems?
Greetings – I’m new to the forum, but been around Street Roding for a while. Sort of...
Sorry to highjack this thread, but I figured it already has knowledgeable people reading it.
I also have an issue with an ’89 IROC 350 TPI in a 37 Ford. About 8 years ago I had salvaged an ’89 IROC 350 TPI, rebuilt it, and rewired in a new ’91 ECU to eliminate the MAF to replace it with a MAP sensor (no room for MAF). I installed an upgraded cam and had Fuel Injector Specialists (FIS) provide a new PROM to match the characteristics to the Cam, 37 Ford, rear end, etc. I also had FIS clean the injectors while I was at it (and polish the TPI runners.) I also installed an adjustable fuel regulator on the fuel rail as well. I successfully got everything up and running pretty nicely. But here is where the problem comes into play...
In 1997 my whole life changed (went back to school, had two kids, moved 1000 miles south) and the vehicle has been sitting untouched (with the same old gasoline) for the past eight years. Now my kids are interested in getting the old car running. As you can imagine the gas had seen better days. I emptied the gas tank and purged out the fuel lines with air. I then put fuel injector cleaner and then alcohol (Heet) in the fuel line and blew this through the fuel lines thinking it may remove some of the varnish in the lines and possibly the injectors as well. I then added fresh gas with more cleaner/Heet to the fuel tank, changed the oil, and tried to fire up the old beast again. But unfortunately it would not start. I had cranked it for a good 10 minutes to no avail. I connected a fuel pressure gauge to the fuel rail and confirmed the pump and regulator were working to the specified pressure, however when I smell the exhaust pipes, there is not a sign of gasoline.
In hind sight, I am concerned that the relatively viscous fuel injector cleaner may be to thick to push through the injectors or possibly the injectors have completely gummed up after sitting for 8 years. As the electrical system had worked fine previous and has been untouched for 8 years, I am assuming everything should be fine in that department. Any ideas on where to begin?
I dread the thought of having to tear down the TPI runners, throttle body, etc. to get to the fuel rails/injectors – I may even have to remove the front end and radiator as everything is so tight in the 37. I never invested in the cable/software for a laptop to monitor the stock computer as I figured the money may be better spent on an aftermarket computer. Where is the best place to get these?
If I only had started it periodically and changed the gas/oil more frequently...
Regards,
JAR37FORD
Old 10-31-2005, 11:29 PM
Well the first thing I'd do would be to get a noid light at your local auto parts store. They plug into one of the injector harnesses and it will flash every time the signal is sent for the injector to fire. This will determine if the injectors are even firing.
Just for safe measure, verify you have spark as well. You just need air, fuel, spark, and the right timing. Air is kind of a given lol, now you just need to verify the other three main components.
Old 11-17-2005, 01:19 PM
stooks8957 stooks8957 is offline
I have any 89 to.
If yours is any thing like mine your fuel lines run under the alternator and and i was getting vapor lock and was doing the same thing. So check if alternator is getting hot and if so try to insulate the fuel lines.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1989 camaro 5.7 Tpi engine experts needed"
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 43 03-09-2008 01:23 PM
5.7 vortec engine management drivin me insane marvinmartian Electrical 11 10-04-2005 10:37 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
1989 camaro engine markh Engine 0 09-30-2002 04:33 AM
76 camaro engine modification everly Engine 3 08-02-2002 07:44 AM
